Art Jett
- Joined
- Mar 25, 2004
- Messages
- 366
- Location
- Azle Tx.
- Corvette
- 1977 TPI 383 stroker, 700R-4/ 2002 6 spd.
I am getting ready to start putting my 383 together and need some advise. I am building a TPI stroker with Edelbrock performer rpm heads. It should be 10:1 compression. I have Sanderson headers and a new 700R-4. At this point I'm not sure if I should use 1.5 or 1.6 rockers. The valve springs will handle the extra lift from the 1.6s but I'm not sure how much I would gain in performance. I'm not going to race the car but at this stage of construction if I can gain a little for not much more cost, why not? I have a Comp cams extreme energy 262H cam. With 1.5 rockers it will have .462I and .469E lift. w/218I 224E duration and 110 degrees lobe separation. I had to go somewhat mild on the duration because of the computer. I have a set of 1.5 roller tip rockers that I got with the heads now but wouldn't object to spending a little more now as opposed to after I get it all together.
