The OEM systems in modern cars are designed specifically for each application, with properly-sized (larger and more efficient) condensers, better refrigerant control systems, and more flexible and effective discharge air distribution systems. They're developed and tested under the most extreme conditions imaginable (including the engine cooling system), and are extremely reliable, with no concerns about low-speed cooling performance or overheating. Almost all are "re-heat" systems, which allow very precise (and frequently automatic) discharge air temperature control.
Aftermarket systems are far more generic, and not as thoroughly developed; they require some adaptations for different applications, and matching the engine's cooling system capacity to the additional cooling load imposed by the condenser becomes a customer-engineering exercise. Properly adapted/engineered/installed, they can be very effective, although almost all of them only operate on recirculated (inside) air, and none are "re-heat" systems, which makes refrigerant and air discharge temperature control difficult.
When I built my Grand Sport ten years ago, I installed a Vintage Air "Supercooler" R-134a system, and you could hang meat in the car, but you also had to accept the system's temperature control limitations (temp control via fan speed).
