B
Barrie
I've owned my '68 roadster since 1970. I just recently installed a
502 Ram Jet. I'm running the old-style, Centerline aluminum wheels with 285/45/15 P7's front and 345/35/15 P7's rear.
Aside from the fact that the Pirellis are getting a bit long in tooth (as am I), I'd like to install larger diameter wheels and taller tires.
The height of the tires I'm running now is about 24 1/2". I'd like to go to 25.5 or 26" high.
I don't want to give up width (the rears I'm running now are about 13" wide). I have plenty of room. Guldstrand "did" the car in about 1983. The fram has been kicked in and I have the L88 flares.
I live in Missoula, Montana, so I can't run down the street and find a supplier. I've done a good bit of searching on the 'net, and called several places. All that I've spoken to say they either don't know anything about it, or they would have the car on-premise to
fit the wheels and tires.
I know what my wheel offsets are and I know how much room I have.
Anyone know of a wheel/tire supplier I can work with?
Thank you, Barrie
Thank you, Barrie
