- Moderator
- #1
- Joined
- Nov 9, 2000
- Messages
- 7,556
- Location
- Edgerton, Ohio, United States
- Corvette
- 1959 black 270hp (9/2/69), 1981 Beige L81(10/20/80)
In 1975 I removed this 1961 270 horse engine from a 1955 Corvette. I put it in a GM engine crate and set it in the corner of my Dad's garage where it sat undisturbed until last week. Dad passed away in January at the age of 92 so now I'm in the middle of settling his estate. Part of that is moving my engines out of his garage. I had originally intended on putting this engine in my '59 but now I'm not so sure. It's a cool thing to have though.
It's a very late 1961.
The block is cast 3789935 and casting dated F201. Block is stamped FO622CU.
The heads are cast 3774692 and cast F161 and F181.
The water pump is cast 3782908. Is this a correct pump?
The carbs are Dec 1960 and the valve covers are old castings without the seams.
The distributor was MIA and I reused the starter so I have no number for that. The car had a 4 speed in it and it remained.
There is no VIN on the stamp pad so I think this was probably a parts counter engine assembly with carbs installed from another source. I think it would be nice to see this engine in a quality restored late June or July 1961 car more than to use it for a driver engine in my '59. Time will tell.
Thought you would like to see an original unmolested survivor engine. The one picture shows it sitting in the corner of my shop. Will it set unmoved for another 30 years?:eyerole
Tom
Tom
