1961 serial number plate
harland
colorado
1961 fawn beige convertible
I acquired an excellent stainless reproduction number plate from AG Backeast in Grand Junction, CO recently. Not cheap at $195. but there isn't another source. I know this tag goes on the steering column, but would appreciate an exact location so we can JB weld it on-or whatever better adheasive might work better. This plate has the reverse dimples that replicate the spot welds (I assume). I wonder also if I should gently 'radius' the tag on something similar to the steering column size as I suspect the original tags had exposed points --a flat plate on a curved surface. Finally, it is beautiful and shiny, but I suspect it may look 'too nice' and wonder if anyone might suggest a way to add some 'patina' to the plate so it doesn't look so obviously new? thanks, Harland
John Mcgraw
Austin Tx
1960 Roman red, 1959 resto-rod, 1965 resto-rod
My 45 year old tag on my 60 looked just like the day it was new. I don't think that any "aging" of the tag is necessary. There was really no effort to match the curve of the column, just the spot welds to the column. The edges of the tag really stuck out from the column.
AG backeast does some really nice work, my 59 has one of his tags on it now. My original tag was almost corroded away from sitting in the bottom of a box that got wet many times over the 25 years that the car was apart.
Regards, John McGraw
harland
colorado
61 Vin tag
Thanks for the reply-so where should I glue the plate--even a real close approximation should work- I suspect the workers put it in slightly different spots when they were installing them. thanks, Harland
