B
bobbyg63
1963 FI High Pressure pump replacement problem
I own a 1963 FI Coupe with the original Hp wobble pump. The car runs very strong, but I just don't trust the pump. Recently I picked up a 1963 Hp gear pump and rebuilt it, new shaft, seal shaft bushings and gasket. The gears were in excellent shape, with very little ware. My problem is when I replaced the wobble pump with the gear pump, and did nothing else to the car, the car would not accelerate. I had a very serious flat spot, and just bogged down under load. When I put the wobble pump back in, the car ran great. My question is why? Does anyone have the specifications on the gears so I can check mine? They don't appear to be worn, but I just don't know. I definately want to install the more reliable gear pump.
