1
19sebringsilver63
ok so here is the deal, i am the proud new owner of a 1963 sebring silver 327 300 4 sp corvette, numbers matching and all original, and unrestored with 90,000 on the clock. drove it home from point of purchase (like 50 miles) car drove perfect, stopped great, no problems at all. well had it out letting my son drive it gingerly. and the right rear wheel ocked up on him. i thought it was because he wasnt used to none power brake cars.
well my son and i took a cruise on sunday and i was driving. and it did the same thing to me, accept everytime i hit the brakes. so we get home and pull the wheel to check the brakes. all looks good, so we pu the drum back on to see if it was hitting anywhere for out of roundness, but what we discovered was a whole new ball of wax.
when spining the drum it would get to a certain point and stop. so my son spun it from the drivers side wheel to get the whole thing to turn, but what happened was that the
torque arm came up, and then went back down!!! it was hitting a spot that was so tuff that it forced the torque arm up, so we removed the drum and duplicated the problem. we have come to conclude that we think it is the half shaft being bent.
anyone out there had this problem? and could this be leading to my brake problem, as the shop manual says that the rear leaf being fouled up could cause the lock up.
also to not the leaf on the passanger side(same side as the problem) has ripples in the leaf spring on the 2,3,4 (from the top) individual leafs.
any help is appreciated.
