L
leoper
Power steering cylinder leaks at the rod seal. I took the cylinder off, removed the snapring, what do I do next? Will anything be damaged, if I just pull on the rod, by using the nut on the end of it, with a piece of pipe between it and the cylinder? Replacement seal kit is available. Any help will be appreciated.
leoper
leoper
