bluegreen454
New member
what does the 3 prong fuse do it is located near the air box on. the passenger side in the engine bay. one lead goes to the super switch,one to the compressor(probably as a ground)and one thru the wiring harness towards the frewall. the air won't work unless i jump the wires in the fuse holder. it will not work with the fuse itself but will work if jumped without the fuse. the compressor is rebuilt and works.the fuses i use are both new old stock and aftermarket. the superheat sw is new.unit blows cold air when the fuse is jumped help!! i'd like to get it to work as advertised>
