Illiad
I need the following parts: dimitri1@twcny.rr.com
rocker moldings with tab
dated 73 ralley wheels
original tires
spare tire lock
center storage compartment with frame (black)
seat shims
battery R-89WT
distributor cap
RFI shield for inside distributor cap
1 upper radiator hose clamp (sure-tight 28)
4 whittek tower clamps 1/16 (dated '73)
t-top bags (dated '73)
washer pump
master cylinder cover (w/o power brakes)
2 '73 mufflers
2 '73 exhaust tips
2 '73 rear exhaust hangers
heater hoses
PCV valve CV736C
left black pillar post molding
RH A.I.R. tube
thermostat housing 336790
battery side post bolt
clips for RH valve cover wiring harness
alternator belt
smog belt
original tires
spare tire lock
seat shims
battery R-89WT
distributor cap
washer pump
2 '73 mufflers
2 '73 exhaust tips
heater hoses
PCV valve CV736C
RH A.I.R. tube
alternator belt
smog belt
