Thanks so much for the pictures, I just ordered a motive unit...When my motive bleeded arrives I will take the master cylinder out of the car , rebench bleed it and try again....
Thanks again
Dominic,
Congrats! You won't regret it. Two large bottles of brake fluid will fill it about half-way. Make sure you have enough in the bottle to avoid injecting air into the system. Also, it is great for flushing the brake system with new brake fluid.
You may not have to remove the master cylinder and bench bleed it. Really, the way to bench bleed a master cylinder is by using a fine clear tubing, but the plastic fittings leak (which is a source or air leak as well). I made a solid bench-bleeding tubing once, but the size was too big (due to the fitting size needed to cinch it down in each port), so this was a losing situation.
The pressure bleeder should get rid of the air bubbles from the master cylinder as well, but to make sure, after you bleed the brakes, release the pressure from the bottle carefully. AND DO NOT DISTURB THE SET-UP. Then pump the brakes through the brake pedal (with enough pressure to simulate a moderate stop) 2 - 3 times, and finally, set the Motive Products' bottle gauge to 20 - 25 again, and go around one more time on the brakes (left rear inner, left rear outer; right rear inner, right rear outer; right front, and left front). That should do it.
Remember that if while driving, you press the brake pedal, and if it tends to kill the engine, then you could have a bad brake booster. With a good booster, a gentle press of the brake pedal should make the pads grab the rotors and slow down the Vette from around 30 MPH at 1/2 way of the brake pedal (approximately; with new brake pads on).
Good luck!
