7
79-L-82
The good:
1979 L-82 4sp.
27K miles.
Dark blue with dark blue leather.
AMFMCB
Glass tops
clock works and is quartz
AC
Power antenna
Power windows
Power Locks
Rear Defog
Factory Spoilers
Tilt/Tele
New oil pan gaskets and valve cover gaskets
New tires 255-60-15
New Shocks and 4 wheel align
Original paint and interior as far as I can tell.
Excellent condition on the inside.
Good condition on the outside
Garage kept and covered.
Frame is good, no rust.
The depends on your opinion:
Hurst Shifter
Smog Pump off But in box
Chrome Open Breather
Chrome PCV breathers
Aftermarket Western Wheels
Holley 650dp
Edelbrock Performer RPM
Light springs in distributer and aftermarket ignition module and coil
The bad:
AC doesn't work. Haven't looked at it because I frankly don't use it.
Radio is weak, but; functions
Paint is OK, shines up good, but; some spider webbing.
Probably some other small things that I'm leaving out.
Very good Vette, runs great.
It sat for 13 years prior to me buying it. Hence the low mileage.
Comes with Hooker sidepipe headers and side pipes that are not installed that are NOT in very good condition.
comes with car cover too.
$17K
1979 L-82 4sp.
27K miles.
AMFMCB
Glass tops
AC
Power antenna
Power windows
Power Locks
Rear Defog
Factory Spoilers
Tilt/Tele
New tires 255-60-15
Hurst Shifter
Holley 650dp
The bad:
$17K
