1980 L82: Rebuilding the Quadrajet...
KANE
Moderator
KY
Dark Blue 1982 Trans Am(s): Polo Green 1995 MN6
Ahhhh... the only reason I'm rebuilding the Quardajet is so that I can get it running long enough to get the VIN inspection over with. Then... this spring... EFI.
Well, it wasn't horribly filthy- I expected sediment in the bottom of the fuel bowl based upon how it was running (rough).
Don't get me wrong- it was dirty (some particle matter under the float), but not as bad as it could have been. What did surprise me was all the slimy white, chalky film on the metering rods. I don't think the carb was even close to being set up right in terms of fuel metering. It was on the rough side.
Good news- the shafts were tight, the metering rods all matched, and there wasn't anything bent.
All the while, I'm remembering why it was that I went to EFI on my 1978 10 years ago. Some people are carb people. Some people are not. I'm with the folks in the second camp.
Anyone have 8x 24lb injectors they want to part with?
  • Thread starter
  • Moderator
  • #2
KANE
Moderator
KY
Well, I got it back together on Sunday, on the car on Tuesday, and fired it up tonight.
Either I've gotten better at rebuilding carbs (not sure how- I haven't rebuilt one in ten years!) or just better at paying attention to detail.
No leaks-just 3.5 turns for the mixture screws- and fired up in less than a minute.
bill81vette
Moderator
Troy,NY
1981 dark blue metallic
sounds like all it needed was a little tlc!!!!!!!
LT4man
Chicago
96 Collectors Edition LT4
There is nothing that sounds like a carbed engine running well.
Congratulations!
I am sure you are better at doing this. Just to be clean and meticulous will get you great results.
SAVE THE :w
