Question: 1981 head light vacuum tank collapsed
corvette81
New member
Auckland, New Zealand
1981 red; 2014 z51 crystal red
Hi this is my first thread so hopefully someone can clarify what has happened to my brand new vacuum tank. Just replaced all the vacuum components, hoses, actuators etc and today noticed the new vacuum tank has completely collapsed. I must admit the new tank is not as heavy duty as the original tank. Going to replace it with my old tank and see what happens. Old tank had a corrosion leak which I have since repaired. Was surprised that the engine could produce enough vacuum to completely destroy the tank. Just wondering if anyone else has experienced this problem.
Antz81
1981 4 speed
Could just be that it's a weaker tank, but wouldn't have thought it would collapse. Do you have a vacuum gauge to check the vacuum? Where in auckland are you?
corvette81
New member
I'm in West Auckland. I found another thread and someone else had the exact same issue with their new can. I think its just a crapy unit. It's definitely a lighter construction compared to the original. They went through 3 replacement cans before purchasing a stronger non corvette replacement. I'm going to refit my old original and see what happens. Sounds like there is only one manufacturer of these reproduction cans. I would recommend no one buy them. I had to modify it to strengthen the three ports as they broke when I tried to fit the tubes.
Thanks for replying.
bill81vette
Moderator
Troy,NY
1981 dark blue metallic
Welcome to CAC!!!
Enjoy!!! Unless you can find an OEM, I'm afraid you may be stuck with the after market.....🤔
Sent from my XT1650 using Tapatalk
Antz81
1981 4 speed
I'm north. But my brother is west. Thanks for the heads up about the can, I still have my original which has no leaks fortunately.
