xfire482
Hello,
Had my first fuel pump problem last summer, my mechanic replaced the pump and the car ran fine. Took the car out of storage this spring, ran fine for a few weeks then died again. I used the service manual to diagose the problem myself and ended up replacing the fuel pump (OK, first pump might have been a lemon). Car ran great with this new pump. Went to start the car 2 days ago and the GD thing wont start. How can this be possible? I cant believe that I got another bad pump! So far I checked the fuses, checked for spark, jumped the oil pressure switch, swapped out the relay, connected 12V to terminal "G". I drained out as much of the old fuel as possible (the tank was quite clean inside) and replaced the fuel filter inside the tank when I replaced the pump. Please, what am I missing????
otfl
otfl
