minifridge1138
I just bought my first Corvette, a black 1982. I got it at a good deal because the previous owner had made some modifications. I bought it from Corvette Country in Austin Texas. They were very helpful, but that's a different story.
Anyway, the previous owner replaced the crossfire fuel injection with a Holley 4-barrel carb, holley intake manifold, and a mechanical fuel pump. Since i bought the car, the Tachometer has not worked. I have the Shop manual, and the diagrams show that the tachometer runs off of the HEI distributor, to a tachomenter circuit board, to the actual guage. When i start my car, the tach jumps to about 2k rpms, and slowly spins all the way past 8k and eventually pins the needle. It does this even if i disconnect the wire going to the HEI. A new circuit is about $200, but given the other modifications, i'm not sure if the circuit is the problem.
Does anyone have experience with the 82 corvette that might have advice about the tachometer? Would it be easier to just replace the whole thing with a mechanical one?
Any and all advice will be appreciated,
-David
-David
