muskiemike
1984 Antenna Grummet removal
Hello,
I've read all of the posts, and have instructions, and have "almost" removed the power antenna from my 84' to replace the broken mast.
Tire's off, wheel well is off, retaining nuts off, disconnected the antenna 3 plug harness at the rear - inside of the cargo area, disconnected the 3 wire antenna tie down, m car is jacked up . . ..
However, I "can not" seem to be able to pull the cluster of the 3 antenna wires through the grommet (rubber) of the body.
When I reach up under the rear fender, I can feel the rubber grommet with the coax and the 3 antenna wires going through it, it seems to have about a 1/4 " lip around it.
But I am not sure if that Rubber Grommet is to be taken off from under the wheel well or what - I can't imagine the wires and connector will pass through that rubber grommet.
Any and all help is GREATLY appreciated . . .
Almost there!
Hello,
Almost there!
