muskiemike
Hello,
I have 84 vet (30K orig miles), had the AC (R12 freon) serviced in 1999, since then I have driven 3K miles and the A/C was not used for months.
When I had the A/C serviced, they replaced the hi & low sensor switch, removed the R12 / Oil, added Ester Oil and 3 lbs of R12 Freon.
Now after 1-2 years of not using the AC, the AC is not blowing cold air.
The repair shop said they it sounds like the o-rings have shrunk, since the AC was not used to keep them oiled and sealing the R12.
So, I am gonna add a can (12 oz) of R12 Freon and see if the cold air will return.
BUT, here's my ?:
If the O-rings are shrunk and not properly oiled, I am thinking that I should run the AC as is for awhile to allow the Ester Oil to pump-up the o-rings, allow them to seal properly prior to adding the R-12 Freon.
Does this make sense, and if so how long should I run the AC prior to adding the R12?
Other comments?
In advance, thanks . . .
BUT, here's my ?:
Other comments?
