Hi folks
any help would be appreciated as mentioned above I have an 84 I replaced the fuel pump and filter and, the vehicle starts if I place a jumper in the fuel pump relay and I can remove the jumper and it stays running, I know on start up on the fuel pump relay should have 12v for around 2 seconds on one of the wires, and it does get voltage but it only around 2-3 volts that read on the meter. now maybe this is related and maybe its not but the cooling fan also quit working now I know the cooling fan is a stand alone from the ECM on the 84 so maybe I am looking at a possible ground issue
Thanks for your time
Jay
Jay
