C
Cherokeecorvette
I took My ECM out of my 85 Coupe becasue i cant read the codes for sum reason, so does any 1 knoe of a place i can send it to get it tested to see if it is working properly??
Will the car run with it in it?????There are several reasons that a ECM won't let you in to read it........................I tried to check the ALDL port, ive taken it to a local repair man and he has a scanner and he said he couldnt read the computer
