1985 L89 Valve Seals
greenstingray
N.J
1985 z51 coupe, 1969 green convertible
My 85 vette will sometimes blow out smoke from the exhaust after driving the car around, then stoping for a while and then when you restart you get a cloud of smoke, looks blue/white. The car will not do this when you start it up in the morning. Only after you have driven around for a while, there is no smoke coming out of exhaust when driving. The car has about 108,000 miles on it, and the previous owner had the car laid up for about 1 1/2 years before I pick it up in April of 01. Someone told me that 85's have a problem with valve seals. Does anyone have any ideas?
c4c5specialist
Technical Advisor
New Haven, Ct. USA
Nope, but someday.
Hi there,
Yes, the oring valve stem seals do crack up, and break creating your condition.
There is a revised seal kit available from GM for this condition.
Besttoyou, c4c5:hb
JT ZR-Won
Bradenton, FL
'90 ZR-1 #3010
Hey, do you own my old '85? :) Just kidding. Mine did that too.
My ZR-1 does that also
Jay
69MyWay
Auburndale, Florida
1969 Killer Shark
No doubt that C4C5 and Chick have had way more experience with this, but for a fellow that pushes paper all day, I have had my fair share of SBC valve stem seal replacment (on the car!).
Most shops will go ahead and suggest a complete valve job to just plain do it right and avoid other problems. However, if you are as stubborn as me and have the extra time, and talent it can be done on the car.
Let me tell you though, this is a pain in the butt job for anybody much less the shade tree mechanic. Here is why, not only do you have to pull the valve covers off, but you have to work in that tiny cramped space to pull the spark plugs, screw in a air line fitting (built mine from a spark plug anti fouler kit, 2' of hard air line and quick snap fittings) one cylinder at a time, pump the cylinder with air pressure, remove the rocker arm, get your valve spring compressor down in that tight space, compress the valve spring, remove the tiny retainer clips on the valve stems, pull the valve spring, clean and remove the old o-ring seal, pop the new perfect circle style seal on, tap it into place, then reinstall the spring, retainers, rocker arm, and spark plug.
When it is all done, you have to go back and cold set, or warm set (whatever you prefer) the valve adjustment and then seal the engine back up. This is a good time to recondition your valve covers, replace spark plugs and wires.
I have done it on four C4s, two S-10s 9one with a V8 and one wiht a V6), and one Gen III camaro all in the car. I hate doing it, but it is well worth it to not see that huge embarrasing puff when you crank it up. It was really bad with my Convertible vette having to choke on that cloud of smoke in front of the whole world when the top was down.
69MyWay
Auburndale, Florida
1969 Killer Shark
Yep, it is a small tool with a claw that snaps around the lower portion of the spring, the handle is threaded to an adjustable mount. You twist it in and out for the desired compression, then clamp the handle over. It gets real tight on the passenger side near the a/c.
greenstingray
N.J
Thanks to all of you for your feed back. I just purchased the valve seal kit from "Last Detail". I think this will be a good winter project. I have one question, where do you purchase the valve spring compressor as discribed by 69MyWay. Someone has told me that the prey bar type that bolts on to the rocker stud will not clear the intake runners.
