renegadeslave
Hello everyone!
My Vette has recently had some overheating issues and I have diagnosed two problems- One, my main cooling fan sounds horrible. I'm installing a replacement motor tomorrow. Two, the main cooling fan was not getting the signal to come on.
I have found the temperature sensor between cylinders 1 & 3 for the temp gauge. I found the sensor between cylinders 6 & 8 for the auxiliary fan. Where is the sensor that provides information to the ECM? I've read on here that it's on the front of the intake manifold, but I haven't been able to locate it.
I've found the relay- works fine. That's how I know the fan sounds like it's about to die. Seems the issue is either the last temperature sensor or the ECM itself.
