J
jhaman
A while back I used the abs, it worked fine but the light did not go out. Since then I replaced the ECM. In the last few days I pulled all wheel sensors cleaned and ohm'd out all the way to the connector in the abs area 1079 ohms? I changed the pump and ran it with a 12v source it ran I changed the abs brain and checked 3 relays the main 12v in, the ground and the abs diode 1.87? How about the lateral accelerator? Right now the abs light is off when I start the car, the relay clicks the light goes off, when I move over 3 mph in forword or reverse the light pops on no pump test sounds I am out of ideas? HELP!!
