1986Conv. L98
ragstoy
Milford CT
1986 convertible 2007 z51
I am experiencing the following issues with my car:
1. My odometer does not work the numbers are all jumbled up
2.My cruise control is not working, a new lever was installed but it did not help
3.My remote control side mirrors will only adjust in and out, not up and down
Any help with these problems will be greatly appreciated.
Rich
Rich
The first place I would start to find out is do all these thing have a comon link like a ground? So I would start by checking the ground points on each "A" piller (thats the ones that the door Hinges are on) there hidden under the door sill molding. there is also a sort of unknown Ground under the A/C / Heater box under the hood on Right side frame rail.
your Cruise may have one other problem the little hose on the Diafram should have Vac. the Larger one should hold Vac. When applied if this isnt happening check for opens in each. Its common for the hoses to rot do to there close to the Battery
