582Boat
Apparently this Corvette was titled out in Canada and then titled out in USA, it just seems that the odometer should show more than 62,000 miles in the condition it is in. I have had the Dealership that has made repairs faxed me copies of repairs, which included such things as, replaced injectors, alternator, starter, rack and pinion, spark plug wires and all this was done with odometer readings at 51,000 miles. Presently the Vette runs good, have just driven approximately 2,000 miles in the last month, coming from Michigan to Florida. The main problems is that the throttle body butter fly hangs up and you must put your toe under the gas peddle to kick the RPM's down. Thinking that the throttle body will have to be replaced, is there any place that I could purchase a good used one or is there anyone that rebuilds them, and what is the approximate cost. Is there anyway one can get information on this Vette while it was licenced in Canada. I have run a Vin fax on this Vette and it only shows me that it was licensed in Canada and then in USA and some Dealership work orders. Any information would be of help in this research.
