M
Michael
1987 Vette with sever miss when hot.
Hey guys, great forum... I'm glad I was referred. I hope that someone out there could help with my current 1987 vette issue. Sorry for the length of explanation, I'm deperate and my mechanic cannot seem to figure the problem out. Please help.
1987 Corvette / Vin. # 8
During the first part of January I was driving on the freeway and noticed that when I stomped on the gas, the car slightly missed before kicking into high gear. This was subtle and intermittent so I didn’t pay too much attention to it and figured it could just be a spark plug or plug wire issue which I was going to be replacing soon anyway.
The problem became less intermittent, and I started noticing the miss when taking off and shifting into lower gears (this is an automatic by the way) so I decided to do a tune up thinking that would be my problem. The following is a list of items replaced during the tune-up.
- Spark plugs
- Plug wires
- Distributor Cap
- Rotor
- O2 Sensor
The timing was set to 6 degrees per spec. and it seemed to run fine right after the tune up. But when the car warmed up, the miss was noticeable still. I took it back to the mechanic and he checked all of the setting with the timing but the computer was reporting that the Throttle Positioning Sensor (TPS) was too low. So that was replaced.
- Throttle Positioning Sensor
This issue still didn’t resolve my problem. After going over the car again, he then thought that what was reporting the error to the ECM that the TPS he suggested that I replace the Coolant temperature that reports to the ECM. That was replaced.
- Coolant temperature sensor
This still did not fix the problem. The car misses slightly when cold, but gradually misses as it became hot to the point where smoke was exiting the exhaust indicating that it was running rich. This error was reported by the 02 sensor as well. The following parts were replaced since then with no change in condition. The car still ran severely rough specially when in gear to the point where it would die and not start until we waited for it to cool down.
- Engine Control Module (ECM) keeping the original PROM chip.
- Replaced the 02 Sensor again to make sure the first was not defective.
- Fuel Filter
- Coil
- Ignition Control Module
- EGR temperature switch (sits on the EGR pipe)
Still this did not fix my problem. The car runs strong when cool, and misses hot where it is could not be driven.
HISTORY
During last summer I replaced the following parts prior to these symptom.
- Mass Air Flow Sensor (MAF)
- All Injectors replaced
- EGR
- Spark plugs
- Plug wires
- Distributor Cap
- Rotor
- O2 Sensor
- Fuel Filter
- Coil
HISTORY
- EGR
