Coupe de jour
My Service LTPWS light is lit on the DIC. I retreived F/C's 24(RR), 34(LR), and 54(RF). I always assumed I had three bad sensors and planned on replacing them when I got new tires.
Recently, I ran over some debris and cut the right rear tire which developed a slow leak. Eventually, the "Low Tire Pressure" light illuminated even though I was getting a fault for that sensor. When I went to get the tire replaced, I had the technician show me the rim before he mounted the new tire. It had the correct orange sensor designated for the right rear but I noticed it had a frequency printed on the sensor. Where these sensors available in different frequencies?
Since the system worked properly, I assumed the control unit was falsely reporting fault codes. I went to the dealer to order a new control unit ($145), but my parts guy told me there was a note in the computer that said the dealer only must disconnect the old circuit board and reconnect the new one.
Does anyone know why the dealer has to perform this operation? Seems like I should just be able to plug in a new control unit.
Thanks,
Kurt
Thanks,
Kurt
