W
wulf
My 92 Z07 C4 with 3.07 rear axle shows a few shifting abnormalities:
1. From gear 1-2 with floored gas, the tranny shifts to 2nd but back to 1 again. This sometimes repeats itself 2-3 times before the tranny decides to shift to 2.
If I do not completely floor the gas pedal but just prevent to touch the kickdown button there is no shift problem. Is the kickdown button responsible?
2. Driving in D (not OD) at around 3000 rpm or more and lifting the gas pedal I would expect the motor break to sart. This does sometimes not happen and the rpms decrease to idle ... If I then give gas again, the tranny seems to "rethink",
and the rpms increase again to 3000 rpm. Driving in OD, the "motor break" function is working as normal.
3. Shift point 1-2 is at the redline while 3-4 is at 4500 rpm. Why that?
Any ideas?
Any ideas?
