1993 rear cargo shade
  • Thread starter Thread starter hooks
H
hooks
Need advise on removing shade--removed one once before, but no way i did it right--took about 2 hours of struggling with screwdrivers & such to eject it from clip it sits in--must be an easy way, right?
Me two
I spent about 4 hours one day trying to remove the shade on my 93. I even had the Helms manuals and it just would not come out. I sure would like to know also how to get it out because I think I will have to replace the antenna and you have to remove the shade to get to the antenna wire.
Don't know about the rear shade but I did have this for the antenna motor replacement. Found it here somewhere. Hope it helps.
1:Remove (in this order) the lisence plate, left backup lamp housing, inner tail lamp housing and finally the outer tail lamp housing (each item is held by 2 srcrews). You can now reach in (unless you have arms like hulk hogan) through the outer tail lamp hole and disconnect/unbolt the antenna.
2:In your hatch area, remove the package (center) tray and remove the cargo shade. Disconnect the antenna and power leads.
3:Pull on the rubber bulkhead grommet until it pops loose and pull the wires out.
4:Now you'll have to lay on your back to get the antenna out from the space between the muffler and the rear quarter panel.
5:Put some vaseline on the grommet when re-installing. It makes it easier to slip in and (hopefully never) take out again.
