1993 Replacement Wheels
tfdvette
New member
PA
1993 Coupe
Can anyone tell me if I can replace my stock wheels with 17x9.5 replacement wheels for all four locations?
I see this is your 1st Post - Welcome to the :CAC
I'd say yes, no problem.
1996 Z51 Performance Handling Package:
Performance-oriented handling suspension tuned for showroom stock, autocross and gymkhana enthusiasts
Bilstein shock absorbers
Stiffer springs
Stiffer stabilizer bars
Higher rate bushings
17" x 9.5" front and rear wheels
P275/40ZR-17 tires
Heavy-duty power steering cooler
Requires 3.07:1 performance axle ratio with automatic transmission
Available on Coupe only
Grand Sport has 17" x 9.5" front and 17" x 11" rear wheels, and P275/40ZR-17 front tires and P315/35ZR-17 rear tires.
If you want go to the bottom of this link/page for the Z51 info:
http://www.corvetteactioncenter.com/specs/c4/1996/96technology.html
Later . . . . . .
6 Shooter
You sure can. You could go 17x9.5 and then easily rotate your tires, or you could go to 18" wheels, and you could even go to 17x11 or 18x10.5 in the rear if you want a larger tire patch. Many C4's came from the factory with 17x9.5.
What he said!
The Z07/Z51 cars from 93-96 all came with 17x9.5 all around. '92 was the last year that all Vettes got the 17x9.5 all around. The 'skinny' front tire/wheel combination was done to make the base and FX3 cars be more stable for the everyday driver.
If you go with the 9.5" wheel all around, you can go with either the 275 or 285 tire all around also.
