1994 door panel removal
L
lcmc
I trying to remove the door panel on my 1994 ZR1. I have taken the plastic push plugs out of the bottom of the panel and it is lose at top and bottom. It is still tight around the door handle and door handle light assembly. What is still holding it on? From the way it looks it looks like the handle and light assembly remains on the door when panel is off.
Toms007
Moderator
Southwest Kansas
2007 Atomic Orange Coupe
There are a couple of screws in the door handle area as I recall. One you must pop out the sliding door lock lever (manual sliding) and it hides behind there. I'm betting that's the one you are missing.
Let us know how it turns out.
L
lcmc
Thanks for the reply.....you are correct it was the hidden screw behind the door lock.
StewB66
OKC, OK
1998 Sebring Silver Coupe
Hey, toms94 and lcmc: How exactly do you go about popping the sliding door lock lever out? I'm a little reluctant to just attack it with a screwdriver blade and the face plate surrounding the door handle is already cracked. I don't want to cause more damage. Thanks a lot!
gmjunkie
Old Fort NC/Vero Beach FL
03 Z-51,78 L82 Coupe
It just clips to the rod,I use a small screwdriver under the front end, and just pop it off!! You don't have to pry against the bezel!!:upthumbs
Toms007
Moderator
Southwest Kansas
Thanks to Junkie for picking this up for me. Yup that's how I did it.
StewB66
OKC, OK
Thanks gmjunkie! I'll give it a try this weekend. I really appreciate the knowledge and quick responses on this website! :w
StewB66
OKC, OK
:w That's a "thank you, too" wave to toms94 in my home state!
Toms007
Moderator
Southwest Kansas
No problem bro. Here's a :louback at ya.
