jmccloud
My 1995 coupe a/c compressor runs all the time even though the heater/ac control is turned off or to heat. I've replaced the a/c relay behind the r/f tire. My interim solution is to unplug the compressor. Any ideas?
Background info: I've had it about 10 months. Best car I've owned. The car has standard heater a/c control. Cools nicely in the summer. The compressor will begin cycling and eventually shut off as the exterior temperature approaces and drops below 40F. So the low pressure cutout is functional. Unplugging the compressor improves performance noticably so I'd like to remedy the situation and eliminate having to raise the hood.
