First of all, thank you very much 6 Shooter (for the solution) and everyone else who posted to the AC doesn't blow through vents discussion. I saved ALOT of money by fixing the AC myself which involved adding a longer bolt and nut on the HVAC and vacuum coupler. It was as difficult to get to as described by everyone and took tremendous patience (which I often lack) but $1 for bolt / nut versus $350 for HVAC programmer.
After fixing the HVAC and replacing the vacuum T under the right rail cover just to make sure, my AC blows cold as ever throught the vents, however when I put the pedal to the floor the ac continues to blow hard and as soon as I let off the gas, the ac turns off completely. I have to turn the unit off and back on at the dash controller and then the ac starts blowing cold again. This is opposite of ever other car I have ever owned. On all of them when you kick it down the ac would slow down and then resume after taking foot off gas and vacuum rebuild. In this case however the whole ac turns itself off and all you get is just the fan blowing when vacuum returns, until you turn unit off/on.
Any ideas from the forum? As additional info, cruise control still doesn't work even after replacing the T. I have vacuum (at least at idle) at the cruise servo under the computer.
Thanks again to everyone.
