sgtrescue
New member
Here's my problem that started about 2 weeks ago. The engine cold starts normal, warms up properly and runs great until you stop driving and shut it off. Approximately 1 -1 1/2 hours later if I try to start the car it misses on 1 or 2 cylinders (extremely rough idle). No check engine light! If you let the car sit about 8 hours or overnight it will start and run great until you shut it off and try to start again after the engine has started to cool down. No smoke or smells! I'm getting ready to do some more extensive testing by warming it to temp and then shutting it off and trying restarts every 15 minutes while recording the engine coolant temps to see if I can determine when the trouble starts in the cool down cycle and (hopefully) when it clears itself. IDEAS/SUGGESTIONS?
