1st to 4th/Cruise control
Reno Rob
Reno,Nv,USA
2006 Monterey Red Vert
The person that I purchased my 1996 LT4 from had a mechanic disable the transmisson 1st to 4th annoyance. It is unknown to me as to what was done. I do know that a CAGS disconnect plug wasn't used. The former owner discovered later that the cruise control no longer worked. Is there a relationship between the two? My goal is to get the cruise control working and then install the CAGS Disconnect Plug.
Also,there is no light that come on the dash that indicates the status of the 1st to 4th shift.
Abingdon,MD
1996 Torch Red LT4
You can just unhook the cags on the tranny and tape up the ends or you can buy the plug that caps them. I doubt that it is related to your cruise control problem unless they really butchered something up. Even with the cags disconnected you should still see the light on the dash for cags. Good Luck, Guy
T
Tanzanite3
Yup!
I have to agree with vetteguy.. I have the CAGS eliminator and my cruise control still works perfectly. I do not think that the two are related .. or, at least the way my 1 - 4 was eliminated did not affect my cruise control! Not positive in your case though!
Michigan
96' LT4
I killed the cags by re-programming the computer.........along with a whole bunch of other stuff..........cruise is fine .............lite is out.........it's as though it never existed.........
