What is the easiest way to replace the parking/sidemarker front lenses on 2002 z06? Could both lenses crack at same time if front lower valance is raked or impacted?
Possibly but unlikely, the easiest is from below with the blockoff panels removed. I've seen alot of mention of doing it from above IF you have a skinny arm by going down beside the headlamps and can feel for the bolts but you can easily see them from below.
