MIZZO6
New member
My 2002 Z06 is leaking fuel and fumes and the check engine indicator is on. After taking it to the dealer it was determined that the gas tank fill hose has a slit in it. The dealer indicated that the only way they could replace the fill hose was to replace the entire fuel tank assembly for nearly $1000. Does anyone know of a better option? Apparently the fill hose is molded rubber in the Z06 while the regular C5 has a straight fill tube. Thanks for any responses.
