2005 and 2006 differences
jaki30
New member
Williamsburg, VA
Other than the 6 speed automatic, are there any other differences that define a 2005 vs 2006?
If I were to look at the 2005, are there any problems that the 2006 corrected?
Thanks.
Boise, Idaho
2002 electron blue Z06
jaki30
Welcome to the CAC! :CAC
I do not know enough to comment much. In the case of the C5, the changes from year to year were incremental. I suspect that the C6 is mostly the same way. The C6 drivers will be along soon to fill in the details.
Dom C
New Jersey
2005 Mag Red Z51 MN6
Corrected in 2006
Thanks.
In a manual trans, the 05 needs to be in reverse or else the battery will drain. 06 corrected that . Also the XM wart on the 05 is hidden in the 06.
Dom C
New Jersey
The steering wheel is different
Thanks.
a peek at the steering will tell you at a glance.
Mustang, OK
'13 427 60th vert - '21 Silver Flare Coupe - CTS V Wagon(4-door Vette)
'06 - differences:
different steering wheel - 3-spoke vice 4
XM antenna in the mirrors now rather than stuck on the roof or rear deck
Little "GM" badge on the rear fender right in front of the rear wheel opening
A6
Other than that, not much.
D
dogface
And lets not forget those all important chrome rings around the dashboard dials.
N
NC-LT4
'07 differences:
No underhood light
No lock on the console
Radio controls on steering wheel on the 3LT pkg
Missoura Ozarks
2012 💯 4LT GS Roadster
'07: 2-tone interior
