Russb
Hi everyone, I'm new to this site and I'm trying to find my way  around to get some info..  I have a 2007 C6 Coupe with 34K miles The crankshaft pulley bolt was loose, the pulley moved and it spit the belts and ruined the serpentine  belt. The air conditioning belt was gone as well. The crank pulley doesn't line up with the rest of the pulleys now. Has anyone else had this problem. Maybe you could share your fix? Is it hard, easy semi easy? Is there a keyway in the crankshaft? I sure could use some help!
