461X (3782461) heads needed
Stan's Customs
Ft. Worth, Texas
Project 1961....
I have some 3782461 heads..they have H195 on one and H215 on the other. I think that is the date code but I haven't tried to look them up. If it isn't perhaps you can tell me where to find the date code. I'll dig them out again and take a closer look (if you think this might be what you need).
Best regards..Stan M.
61 Silver
Wyoming N.Y.
1961 270HP and 1963 340HP
Hi! Stan
The codes you listed are for a chevy small block 1965. The heads that I need are similar, but will have a date code that will end with a "0" and the numbers 461. There will also be an X symbol on the heads. These heads are for a 1961 fuelie and will be very expensive. The symbols are a little different (flat tops on the humps) than the later double hump 461 heads.
Thanks for taking the time to answer my add.
Ray
61 Silver
Wyoming N.Y.
Thanks for the responses! I have found and purchased the correct dated 461X heads for my project car.
Ray
