461X heads
bigben
Houston,Texas
1971 Stingray
I have a set 461X Heads I no longer need! Date codes appear to be july 1962 Excellent condition. 2.02 valves ,screw in studs and pushrod guideplates. What might they be worth??
Thanks BEN;shrug
they were in big demand before NHRA allowed super stock cars to used ported heads. if you are looking for more performance there are a lot better performing cast iron heads in the after market and from GM
Did not know about the rule change,might explain why not as much interest as I expected.
Ben
They're probably not worth much to someone doing a restoration because their modified with the screwed in studs and guideplates.
As someone else said they're of not much use to drag racers anymore and hot rodders may not want them because they have soft valve seats and, thus, cannot be used with unleaded fuel.
Good luck.
