54 E Brake Warning Light
Oregon Ohio
2015 Z06 Callaway White, 1967 Corvette RestoRod
I would appreciate it if someone could tell me how to remove the E Brake warning light. As you can see one wire is removed.
Do it remove it from the front, twist it off at the back or some other way.
Not much room under there to dance around. :L
Thanks,
Roger
Thanks, I tried push and turn and did not get anywhere. :w
Also, where do you get power from. Since the EBrake is an "option", it is not listed on the standard 54 wiring diagrams that I have looked at.
I think it should get power from the pink side of the junction box.
Roger
Roger,
Push in and turn to the right, but you have to hold the light so it doesn't push back into the cockpit. Hope this helps.
Jim
Thanks Jim and Guy. :w I was able to remove the light.
Also, I looked on wiring diagrams for 58 and saw that their power indeed did come from the pink (keyed) side of the junction box.
Another fix because of help from CAC members. :w
