T
		tkrphxr
I need some info on the oiling system. I have a friend building the engine for his 56 and is having a problem with the oil system. I understand from him that this is what is called a late 56 265 block. The first time they put the engine in they could get no oil to the lifters or the cam bearings. I have been told that on this particular engine the rear cam bearing is supposed to have three oil holes in it and I have looked at the block and you can see three distinct oil galleries. There is on for each side for the lifter galleries and one in the middle for the cam bearings. I was also told that the rear cam journal is supposed to have a grove around it to let the oil pass from the block throught the bearing to the Lifter galleries. The machine shop insist that the cam bearing is only required to have two hole. Can any one please help me. I hate to see them put this engine in and have more problems.  Please please help Thanks in advance Charlie
