59 front wheel bearing conversion
  • Thread starter Thread starter Toni
T
Toni
I would like to replace the ball bearing wheel bearings on the front of a 59 with roller bearings. Has anyone here done this swap before? If so do you have the bearing and seal numbers that you used? Did you run into any problems? I am new to this board but there sure seems to be a lot of good technical information on here. Thanks for the help.
Toni Holliman
ALLIED BEARING
8962 Ellis Ave
Los Angeles, CA 90034-3378
800-421-3658
Be sure to tell them you belong to a Corvette club, SUPPOSEDLY you should get a discount. Corvette Central also sells them, but only in sets (at a higher price), and you can buy them individually from Allied.
I have them on my 57, a friend has had them on his 56 for many years.
They are a direct replacement for the ball bearings.
Verle
I used the Corvette Central set on my 59.
The seals are the exact ones used as stock with the same numbers.
I did post the bearing numbers some time ago on one of the other forums but from the responses I got, there wasn't that much difference in the price from the bearing houses.
No problems with the tapered set but as I rebuilt the entire front end at the time I can't really determine if there was any real improvement from the ball bearings.
Mark.
My cost for the bearings and seals with shipping was right at $100 from the above source.
Verle
