Boy - Tremec sure has the 'Buzz' thing going.
A friend paid over 4k for the Kiesler Tremec 5 kit (new bellhousing, new driveshaft, etc, etc.) for his 69 427 roadster.
Problem #1- the trans has to be installed with the bellhousing! PITA.
Problem #2- the trans needs the offset belhousing pins- fit is crucial.
Problem #3- the trans was defective! After removing the entire setup for the 3rd time, he sent it to Kiesler, where it evidently sat in the corner for months.
Finally, after being without his car for most of the season, he called Kiesler. The answer: "Oh, did you send us a transmission"?
ad
The setup works OK now, but it's big$$$ and PITA install, with shoddy customer service.
I've got another gear, closer ratios, stock GM dimensions, and almost 2k in my pocket compared to him.
But he just HAD to have the Tremec"hot setup"- Hecho in Mexico. :L
