Welcome to the CACC Lou. It's always nice to have another LT4 owner around.
As for the boot. I think you can just pop off the sift pattern plate and there is a bolt under that that you can tweak to tighten it up. Hope this helps.
When I said mechanically challenged, I did not mean somewhat, more like totally. In any case, the only shift pattern is on the gear shift itself. The screws that are loose( other than the ones in my head) appear to screw into the bottom of the console, so it would seem some how I need to lift the console or some part thereof to get to them.
Thanks again, look forward to this web site, best I have seen for vette nuts.
If you open your center glove box, there should be 2 screws that go in sideways for the section with the shift boot cut out. I believe there are 1 or 2 screws underneath the ashtray, and then 2 screws in the front of the piece, underneath the plastic part holding in the stereo......try that and see if it works. I recommend a magnetic phillips screwdriver so you don't lose any screws
Thanks for all your help. As soon as the temperature here in Colorado gets above freezing, I'll see if I can get it done without making things worse(which is normal for me).
