I have never done this kind of thing before and I dove head first into taking mine off and even went further with front and rear suspension changes, new 5 speed, side mount motor mounts etc etc.
I am glad I did, best thing I ever did!!! If I did it, I am convinced anyone could do it!!!
here is a link to over 500 photos of my car in various stages from the beginning to the present!
http://public.fotki.com/htmiata/1960_corvette/
first body lift!!! wow was that easy with the 4 post lift!!!
couple of the guys I had never met in person before from the forum came over to help, they were GREAT! I was glad that they were there!
first of many times that the body would be on and off the dolly and back on the frame for fitment testing and checking clearances as well as tire and wheel fit.
I hadn't welded in over 34 years. Bought a stick welder at a local auction, my tacks were pretty ugly, but they held until a professional took care of getting everything properly welded!
another of the many body lifts I was able to do by myself. got so good at it I could do it in 45 minutes from start to having it back on my other lift. I was pretty amazed. With one of these 4 post lifts it was extremely easy to do.
my frame all powder coated with the new suspension pieces. Ford 9" rear, disc brakes all around, rack and pinion steering, coil over shocks....it is great working with cleanly painted pieces! The silver parts are all powder coated silver with clear powder over them.
media blasting the body, had to replace the front hood surround.
I had to figure out what to do for exhaust and Allen Exhaust had just the thing, a side exhaust that mounted under the body out of sight that runs between the outside of the car and the frame rails.
my body with the front surround starting to be pulled off!
my motor
body shop had to mount the body back on the frame and used the frame as a jig to get everything aligned properly! Next time the body goes back on will be the last time!
this is pretty close to where we are today, the shop has the body in tinted red primer and are finishing off the motor compartment and will soon be shooting the body...we are about 3 to 4 weeks from getting it home!!!
So there you go. Once you get started you will do more than you planned and spend about 2x the money you thought you would. But I think it is worth every penny!!! Good luck on what ever you do!!!
regards, Herb
