R
Rick Daniel
11-11 Automotive Design and Production Magazine
" When Chevrolet rolls out the 6th gen Corvette at the North American Inter. Auto Show in January, the Gen 4 V8 will have a reported 405 hp, the same as the current Z06. Insiders at both GM and suppliers say the Z06 will have an even 500hp, but will not be the most powerful Corvette. That prize will belong to the limited production ZL1 twin turbo which is producing 625 hp in production trim. The Gen4 has thinner bore walls, stronger bulkheads, and retains the cast-in-place iron cylinder liners. The casting process includes a mechanically induced rapid chilling of the bulkheads to promote swift directional solidification of the aluminum and a fine grain structure , both of which improve dimensional stability. A composite barrel crank core replaces the current segmented barrel design, again for tighter and more consistant bore dimensions. The cores are screwed and glued together, the aluminum is pumped in rather than poured, and all the oil galleries are drilled and machined.":eek
Now this make a lot of since.
Lutz speaks to Edmuns.com
You did the Viper during your stint at Chrysler, and now Neil Hannemann, who led the Viper team, is doing the GT at Ford. Does GM need a Viper/GT class vehicle, or is the Corvette strong enough to handle that role?
Let me tell you that the Corvette C6 will have versions where we confidently predict it will suck the doors off of both the cars that you just named.
