1KULC7
Got out to visit, and behold...the painter has gone to PRIME Time... This is the FIRST coat of primer/filler. Next stop is block/sand, clean, then next step another coat of primer...then we let it cure.
So here are the photos I took about an hour ago. Things are really coming together and you can finally see all hard work that went into replacing and aligning body panels and all that hard work on the body, including the long list of suprises that we found under the tons of paint that was removed. I am very happy with the results and each day getting more and more excited over getting to the finish line.
Looks like we are STILL on track for Carlisle and its going to be real real close....here are the photos...
Passenger's side...
This is the car after priming but still needs to get blocked and sanded...
Passenger's side...
![web_2.jpg](http://temp.corvetteforum.net/members/tempsites/ebvette//1963Coupe/Primer/web_2.jpg)
![web_3.jpg](http://temp.corvetteforum.net/members/tempsites/ebvette//1963Coupe/Primer/web_3.jpg)
![web4.jpg](http://temp.corvetteforum.net/members/tempsites/ebvette//1963Coupe/Primer/web4.jpg)
![web5.jpg](http://temp.corvetteforum.net/members/tempsites/ebvette//1963Coupe/Primer/web5.jpg)
![web6.jpg](http://temp.corvetteforum.net/members/tempsites/ebvette//1963Coupe/Primer/web6.jpg)
