HF is 300 HP not 25061 Silver said:Garth64
I do not have a picture of a 64, but here is a photo of my original 1965 250HP stamp.
Rayhttp://home.rochester.rr.com/splitwidow/MVC-026S.JPG
Ray![]()
ChuckG said:Here are a couple of engine stamp pix.
Tempus, something doesn't look "right" with your VIN derivitive. Incorrect "format". Also, the pad looks like a 350 pad, not a 327 pad. Note the front or leading edge. Yours is flat, the others have a projection. Chuck
Tempus_Fugit said:This is somewhat disturbing, not exactly what I needed to hear, but I appreciate the input. I did note that I am not an expert, and this development may provide evidence to that.
I will look at the other numbers (Casting & date) and report back.
thank you,
John Myers
[/QUOTE] you can thank this "matching numbers" thing for taking corvettes that are worth $25,000 and have some guy with a hammer and a set of stamps turn it into a $50,000 corvette. maybe i am thick but i can not see how a 40 year old corvette can be worth as much as a new corvette. remember i owned those corvettes when they were new and there is no way they compare to my new C-6. i know my C-6 will depreciate in value but if i was looking for a investment i would call my stock broker. there is going to be a lot of "investors" who bought restored corvettes that are going to be disappointed in the end because they are going to lose more money than i am on my C-6. JMHOTempus_Fugit said:This is a little disappointing, at least I still have my health.
What is the correct spelling of NOM? :s
Anyway, see attached, date is tough to read but looks like
G235
The good news is that my new camera works really well.
thanks for all the help
John Myers
Milwaukee
Did you find the casting date of the block? Chuck
The block casting date of G235 translates as: July 23, 1965. That "fits" with the assembly date of Sept. 15. They began building 66 Corvettes in September of 65. In 66, GM "switched" to the "174" block, and quit using the "870" in the Corvette. ChuckChuckG said:Your assembly date of Sept 15 would be for a 1965 car, not a 1964, as they began building 65's in August of 1964. What is the casting date of the block, located on the bellhousing flange near the distributor?
A 64 with your VIN would have been assembled in early May of 1964. Chuck
